InitParameters Member List
This is the complete list of members for InitParameters, including all inherited members.
camera_disable_self_calibInitParameters
camera_fpsInitParameters
camera_image_flipInitParameters
camera_resolutionInitParameters
coordinate_systemInitParameters
coordinate_unitsInitParameters
depth_maximum_distanceInitParameters
depth_minimum_distanceInitParameters
depth_modeInitParameters
depth_stabilizationInitParameters
enable_image_enhancementInitParameters
enable_right_side_measureInitParameters
InitParameters(RESOLUTION camera_resolution_=RESOLUTION::HD720, int camera_fps_=0, bool svo_real_time_mode_=false, DEPTH_MODE depth_mode_=DEPTH_MODE::ULTRA, UNIT coordinate_units_=UNIT::MILLIMETER, COORDINATE_SYSTEM coordinate_system_=COORDINATE_SYSTEM::IMAGE, bool sdk_verbose_=false, int sdk_gpu_id_=-1, float depth_minimum_distance_=-1., float depth_maximum_distance_=-1., bool camera_disable_self_calib_=false, int camera_image_flip_=FLIP_MODE::AUTO, bool enable_right_side_measure_=false, String sdk_verbose_log_file_=String(), int depth_stabilization_=1, CUcontext sdk_cuda_ctx_=CUcontext(), InputType input_type=InputType(), String optional_settings_path_=String(), bool sensors_required_=false, bool enable_image_enhancement_=true, String optional_opencv_calibration_file_=String(), float open_timeout_sec_=5.0f)InitParameters
inputInitParameters
load(String filename)InitParameters
open_timeout_secInitParameters
operator!=(const InitParameters &param1) constInitParameters
operator==(const InitParameters &param1) constInitParameters
optional_opencv_calibration_fileInitParameters
optional_settings_pathInitParameters
save(String filename)InitParameters
sdk_cuda_ctxInitParameters
sdk_gpu_idInitParameters
sdk_verboseInitParameters
sdk_verbose_log_fileInitParameters
sensors_requiredInitParameters
svo_real_time_modeInitParameters
