Mat Member List
This is the complete list of members for Mat, including all inherited members.
Alloc(uint width, uint height, MAT_TYPE matType, MEM mem=MEM.CPU)Matinline
Alloc(sl.Resolution resolution, MAT_TYPE matType, MEM mem=MEM.CPU)Matinline
Clone(Mat source)Matinline
CopyTo(sl.Mat dest, sl.COPY_TYPE copyType=COPY_TYPE.CPU_CPU)Matinline
Create(sl.Resolution resolution, MAT_TYPE type, MEM mem=MEM.CPU)Matinline
Create(uint width, uint height, MAT_TYPE type, MEM mem=MEM.CPU)Matinline
Free(MEM mem=(MEM.GPU|MEM.CPU))Matinline
GetChannels()Matinline
GetHeight()Matinline
GetInfos()Matinline
GetMemoryType()Matinline
GetPixelBytes()Matinline
GetPtr(MEM mem=MEM.CPU)Matinline
GetResolution()Matinline
GetStep(sl.MEM mem=sl.MEM.CPU)Matinline
GetStepBytes(sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out float value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out float2 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out float3 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out float4 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out byte value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out char2 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out char3 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetValue(int x, int y, out char4 value, sl.MEM mem=sl.MEM.CPU)Matinline
GetWidth()Matinline
GetWidthBytes()Matinline
IsInit()Matinline
IsMemoryOwner()Matinline
Mat()Matinline
Mat(System.IntPtr ptr)Matinline
Mat(sl.Resolution resolution, MAT_TYPE type, MEM mem=MEM.CPU)Matinline
MatPtrMat
Read(string filePath)Matinline
SetFrom(Mat src, COPY_TYPE copyType=COPY_TYPE.CPU_CPU)Matinline
SetTo(ref float value, sl.MEM mem)Matinline
SetTo(ref float2 value, sl.MEM mem)Matinline
SetTo(ref float3 value, sl.MEM mem)Matinline
SetTo(ref float4 value, sl.MEM mem)Matinline
SetTo(ref byte value, sl.MEM mem)Matinline
SetTo(ref char2 value, sl.MEM mem)Matinline
SetTo(ref char3 value, sl.MEM mem)Matinline
SetTo(ref char4 value, sl.MEM mem)Matinline
SetValue(int x, int y, ref float value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref float2 value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref float3 value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, float4 value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref byte value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref char2 value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref char3 value, sl.MEM mem=sl.MEM.CPU)Matinline
SetValue(int x, int y, ref char4 value, sl.MEM mem=sl.MEM.CPU)Matinline
UpdateCPUFromGPU()Matinline
UpdateGPUFromCPU()Matinline
Write(string filePath, int compressionLevel=-1)Matinline
